When I hit the "loop out" button, the song goes to another place in the song. Ideally, when I cancel the loop, I want the song to continue playing from where I hit the out button. So, if the song has an eight bar intro, when I cancel the loop immediately after it hits the first bar, I want it to play the remaining seven bars. Instead, it picks up at the seventh or eighth bar. How can I fix this?
geposted Sun 31 Jan 16 @ 10:33 pm
is loopback enabled?
geposted Mon 01 Feb 16 @ 12:31 am
Loop out just cancels the loop here and the song keeps playing from its current position. Are you sure you don't have slip enabled on deck ? Also I would suggest you to check the mapper if this happens with a controller in case you messed up the code by accident.
geposted Mon 01 Feb 16 @ 2:11 am
