i Was Experimenting with Virtual dj 7 and 8, i found a way to carry my BPM's from 7 to 8 but when i load the Track on 8 it Resets the bpm that i edited to 94 to 125. How do i make the Virtual dj 8 Not Change it back to 125 but keep it at 94
geposted Mon 01 Feb 16 @ 3:05 am
When you import your VirtualDj 7 database to VirtualDj 8, VirtualDj has to rescan the files.
Once the files are rescanned then any manual changes you make they are saved.
geposted Mon 01 Feb 16 @ 11:24 am
Well im still playing around with it, I Re edit the BPM back to where its supose to be then i re open the software, it still goes back to 125, so i tryed to go to Tag editor and i Change the Value of the BPM along in the bpm editor aswell and i click write tag. Then it seems to stay at 94 BPM. But i think its too much work to get it to stay at 94 BPM, there should be a Feature that lets you shutdown the Scan. (If BPM = writen in database do nothing else, scan bpm) kinda anoying to prebuild your lists then have to go trough it again in virutal 8 and the tools arnt so good.
geposted Mon 01 Feb 16 @ 1:18 pm
