Hello,
Im hoping to get some help in setting up the audio configurations with the Gemini MDJ1000.
I've tried just about every possible configuration, and I can't seem to get it right.
Help please.
Help please.
geposted Tue 02 Feb 16 @ 6:10 am
Did you follow the instructions of the VDJ Setup Manual ?
http://www.virtualdj.com/documents/Gemini%20MDJ1000%20-%20VirtualDJ%208%20Operation%20Guide.pdf
geposted Tue 02 Feb 16 @ 6:43 am
Yes sir. Its in the asio configuration that im havi g an issue.
geposted Tue 02 Feb 16 @ 6:44 am
can you post a screenshot of your current audio setup in VirtualDj ?
And what is your OS please ?
geposted Tue 02 Feb 16 @ 6:46 am
This is where im stuck.
geposted Tue 02 Feb 16 @ 6:52 am
For some weird reason Im not being able to upload the pic.
geposted Tue 02 Feb 16 @ 7:06 am
My OS is windows 10.
geposted Tue 02 Feb 16 @ 7:07 am
please make sure, your picture is a png file.
Are the Asio drivers of the gemini W10 certified ?
geposted Tue 02 Feb 16 @ 7:19 am
Gemini Asio driver downloaded directly from the gemini website. I had a similar issue when I had the Gemini CDJ700.
In the Asio section it sees bith MDJ1000 on ch group i have lefr channel, right channel and this is where im having problems.
geposted Tue 02 Feb 16 @ 7:22 am
please try again to post a screenshot of the VDJ Audio setup please
geposted Tue 02 Feb 16 @ 7:43 am
I will try tomorro from my office. Thank you all for your help up to this point and I hope we can get this issue solved bedore Friday night.
geposted Tue 02 Feb 16 @ 7:45 am
This is where I'm having problems. I can't figure this part out to get the sound to come out correctly. Help please.
geposted Tue 02 Feb 16 @ 2:56 pm
please try to set both decks on channel 1 & 2
geposted Tue 02 Feb 16 @ 3:00 pm
you're not being clear, set both decks as 1&2 on which step from the pictures posted?
geposted Tue 02 Feb 16 @ 3:01 pm
sorry ... meant the first one ... did you made any changes in the asio window too ?
Please try to relaunch your system after you made the changes in VDJ and check if the asio window
pick up the settings automatically
geposted Tue 02 Feb 16 @ 3:03 pm
I had both as 1&2 and it didn't work, I moved around the ASIO configuration and nothing. Either the left channel plays on the right channel, or the the right channel plays on the left and on, but no luck so far.
geposted Tue 02 Feb 16 @ 3:05 pm
If it's just left and right decks that are swapped, set deck 1 to channel 3&4 and deck 2 to channel 1&2
geposted Tue 02 Feb 16 @ 3:07 pm
tried that too :(
geposted Tue 02 Feb 16 @ 3:30 pm
It's the sound that is wrong or the controls?
If you press play on the left deck, and it's starting playback on the right deck, that's something you need to switch around in the controller config, not the audio config.
geposted Tue 02 Feb 16 @ 3:57 pm
If I press play on the left controller, on Virtual DJ it also plays on the left, same thing with the right side. It's just the sound that keeps coming inverted or the sound from the right channel comes out on both channels on my mixer.
geposted Tue 02 Feb 16 @ 4:07 pm
