Forum: VirtualDJ 8.1 Technical Support
Topic: MIDI LATENCY ISSUES
On the pioneer decks and controllers somehow the scratch doesn't seem as accurate as it should be even with adjusted jog settings and latency set to 5.8ms 24bit. I also notice that browsing becomes sluggish after prolonged use. Searching for a track takes a while to narrow down search and refresh browser like lag.
System specs
i5 Sony
8gb ram
Radeon graphics
geposted Wed 03 Feb 16 @ 3:40 pm
Can you try with the latest Early Access build 2832 ?
geposted Wed 03 Feb 16 @ 5:37 pm
I will do tonight
geposted Wed 03 Feb 16 @ 7:57 pm
Browser still takes a while to refresh after extended usage of midi controllers. First 30 mins are fine but browsing slows down after a while like there is a memory leak. I do not get audio dropouts just the browser taking a while to update results
geposted Fri 05 Feb 16 @ 4:54 pm
Aee you using the internal HD or an external HD?
I've noticed this slow down but figured it was because I use an external HD.
geposted Fri 05 Feb 16 @ 7:47 pm
I'm using internal SSD
geposted Fri 05 Feb 16 @ 9:45 pm
First seen field is selected/visible ?
If Yes, can you try without it ?
geposted Fri 05 Feb 16 @ 10:01 pm
System specs
i5 Sony
8gb ram
Radeon graphics
Set latency to 1ms
geposted Sat 06 Feb 16 @ 10:33 pm
There are advanced options concerning exactly scratching. Something like spin up or spin down or at least spin something... Take a look ;)
I hate lag too. I always tell my bro his PC lags before he beats me at a video game hehe....
Lower latency for your ASIO drivers, then tweak the advanced scratching options to your liking.
geposted Sat 06 Feb 16 @ 11:06 pm
Read too fast. it might be a disk tweaking issue. I don't have ssd, but as I'd like to upgrade I did some research, and to my surprise found many threads concerning lag/spiking issues with SSD.
In this link, maybe you'll find some hints at solving the issue... it's not much info, but a few anecdotes I found interesting.
http://superuser.com/questions/488782/intel-ssd-330-lags-on-windows-8
geposted Mon 08 Feb 16 @ 4:48 am
