Forum: VirtualDJ 8.1 Technical Support
Topic: Resetting my setting
hipfanPRO InfinityMember since 2010
Just courious why my cross fader setting keeps changing when I shut down and restart vdj8 the rest of my settings stay where Iset them
geposted Wed 03 Feb 16 @ 5:25 pm
RobRoyPRO InfinitySenior staffMember since 2012
what does change exactly ?
geposted Wed 03 Feb 16 @ 6:28 pm
The cross fader goes from full to 3.765566 or 4.7566as an example
geposted Wed 03 Feb 16 @ 6:31 pm
did you aready checked the oninit in the mapping file ?
geposted Wed 03 Feb 16 @ 7:12 pm
Nope but will try that
geposted Wed 03 Feb 16 @ 7:14 pm
if there is no entry and the issues still present you can try to add "crossfader 50%"
geposted Wed 03 Feb 16 @ 7:15 pm
Thanks Rob appreciate the help
geposted Wed 03 Feb 16 @ 7:17 pm
If you are using the NS7 (thats what i see in your Account data), then the crossfader curve is defined by the position of the XCURVE knob of the NS7
If you dont want that knob to define the crossfader curve then you need to delete the action from the mapping.
geposted Wed 03 Feb 16 @ 8:08 pm
Excellent thanks so much
geposted Wed 03 Feb 16 @ 8:39 pm
