In Windows 10, new folders were created on my external drive and music copied to those folders. In File Explorer everything views perfectly. However, none of the new folders, and hence not the new music files either, are picked up by VDJ 8.1!!
What's the issue? Help appreciated. Thanks Jules
geposted Thu 04 Feb 16 @ 2:08 pm
Update on above. The 'missing' folders have been found but instead of listing them all alphabetically as normal, the three new folders are to be found after "Z"!! Previously hey have listed alphabetically. Very strange.
geposted Thu 04 Feb 16 @ 2:30 pm
find and delete your .order file on the external [externally], [is this a option inside v8 i can't remember?]
geposted Thu 04 Feb 16 @ 6:26 pm
will take a look at that thanks. Weird how things would suddenly change after doing ordering completely OK for years.
geposted Fri 05 Feb 16 @ 3:16 am
You can right-click the folder that is sorted wrong and select 'reset sort order'
This will start happening when you (accidentally perhaps) manually drag a folder to a different location.
geposted Fri 05 Feb 16 @ 6:22 am
