Forum: VirtualDJ 8.1 Technical Support
Topic: Another BPM issue
Djsho3kPRO InfinityMember since 2009
Is there anyway to batch edit a bunch of BPMs(change 180 to 90) or can VDJ be set to only use a set BPM range....say 60-120?
geposted Sat 06 Feb 16 @ 6:33 am
If they are all double or halved, yes, but they have to be done separately. For those needing to be doubled, select all, right click, tag editor, and go to the BPM slot, and hit x2. If needing to be halved select /2.
geposted Sat 06 Feb 16 @ 6:51 am
thx!!!!!
geposted Sat 06 Feb 16 @ 8:58 pm
