Forum: VirtualDJ 8.1 Technical Support
Topic: Crash on delete
ChreecePRO (OEM)Member since 2014
I had 2 crashes yesterday when i was trying to delete a file through VDJs browser, when i was live having tracks loaded on 2 decks
geposted Sat 06 Feb 16 @ 5:27 pm
Mac or PC, which build number, and can your repeat it today?
geposted Sat 06 Feb 16 @ 9:31 pm
PC latest build.
I tried today to reproduce it but couldn't. Maybe because the controller is not connected. Also yesterday i noticed after using Tag Editor the controller was for a second disconnected and reconnected, with the the deck that wasn't on air acting like there was no track loaded on it (it was on VDJ) until i turned a knob i think (can't be sure)
geposted Sat 06 Feb 16 @ 9:40 pm
Please try to reproduce using the same equipment that you had the issue with. Check your USB cable, or change it.
geposted Sat 06 Feb 16 @ 9:43 pm
