wussup to dj usesrs or staff members I having issues using the Broadcast system apply 8.1 can someone give me a hand in that department
geposted Mon 15 Feb 16 @ 10:08 am
What is the problem?
geposted Mon 15 Feb 16 @ 4:45 pm
I'm having issues new virtual dj 8.1 I'm in a new radio dj problem called radio.co now it able too support virtual 7.4 but not virtual dj 8.1 can u help me out
geposted Sat 05 Mar 16 @ 3:57 pm
I keep seeing disconnted section
geposted Sat 05 Mar 16 @ 5:17 pm
I think i still don't get your problem.
Are you saying that radio.co station only supports VDJ 7.4 but not VJD 8.1?
If that is the case you should ask radio.co for support.
Or use a shoutcast server, connect to it from VDJ and connect from the shoutcast to radio.co.
geposted Mon 07 Mar 16 @ 9:49 am
