Hi all, For awhile now I've had a few .VOB files freezing the video but not the audio. No big deal I can live with that knowing which ones they are. Last night however almost every .VOB file would freeze. I don't really want to convert about 3500 .VOB files to MP4 if I can avoid it!!.Win7 VDJ8 latest build. This only happens when connected to external screen. Any thoughts? Regards, Steve.
geposted Sun 21 Feb 16 @ 1:16 am
let's see if this will help (just guessing).
on config/option/video, videouseDXVA (use the search for DXVA it;s quicker, make sure advance is tick), change it to NO (I think default was YES).
geposted Sun 21 Feb 16 @ 3:43 pm
Sorry for late reply. DXVA already set to no. thanks anyway.
geposted Sat 27 Feb 16 @ 1:04 am
Would it be possible to send me one of these vobs so I can have a look?
geposted Sat 27 Feb 16 @ 3:02 am
Yeah I can. Give me a couple of days. A lot of other stuff going on right now!
geposted Mon 29 Feb 16 @ 11:27 am
OK, Finally have some free time. How do I sent one of the problem files to you Adion?
geposted Wed 02 Mar 16 @ 7:05 am
Easiest way is to upload it to something like dropbox or any other cloud storage and then provide a download link.
geposted Wed 02 Mar 16 @ 9:35 am
Ok. First time I've tried Dropbox so lets see how I go!!
https://www.dropbox.com/s/56x2695jxx9q3sv/Rick%20Springfield%20-%20Jessies%20Girl%20%28V%29.VOB?dl=0
geposted Thu 03 Mar 16 @ 9:35 am
Played perfectly first time in VDJ on my laptop using the on-chip Intel graphics. I then swapped over to the AMD Radeon HD 6630M and it played on that card too.
Must be something to do with your configuration or video drivers.
Here is my video config:
geposted Thu 03 Mar 16 @ 10:06 am
Thanks for taking a look. Do you have external screen hooked up? I can play it perfectly as well without an ext screen. Only happens when ext is connected. I'll compare video settings tomorrow.
geposted Thu 03 Mar 16 @ 10:33 am
Just ran it from HDMI (external display) to my Samsung 55" LCD and again it played fine.
geposted Thu 03 Mar 16 @ 11:04 am
Hmmm
geposted Fri 04 Mar 16 @ 11:03 pm
Try deleting your settings.xml and try again
geposted Fri 04 Mar 16 @ 11:36 pm
Videoforcefullscreen I've set to 1. Mine was on 0.
Also changed Videomaxmemory to Auto. Mine was on 256 for some reason.
Seems to have fixed it!!! So far.
Something so simple!
Testing lots of vobs to make sure!
geposted Sun 06 Mar 16 @ 2:19 am
