I was told in online chat that because DDJ-RX was almost a mirror of the DDJ-SX2, it would work with my DDJ-RX that I just purchased, (it's not listed in drop-down menu).
I currently have one computer that has the WEGO of which I no longer want to use. I need a program on two computers,(one back-up) of which I was told I was allowed. How do I connect my new DDJ-RX properly to both?
MY computer is a Toshiba PC in case you need to know. Thanks
geposted Sun 21 Feb 16 @ 12:46 pm
Please have a look to this link. Login and Licencing Procedure his quite detailed explanied here:
http://www.virtualdj.com/forums/187806/VirtualDJ_8_0_Technical_Support/Virtual_DJ_8_-_Login_and_License.html?page=1
geposted Sun 21 Feb 16 @ 1:09 pm
I viewed this page and understood all it said. However, when opening the program and going to the configuration, I had problems when going to the license section. Where it says add/change controller, it was a dead link to do so. I'm trying to change from a WEGO system to my new DDJ-RX controller system. I need to know how to do that
-Thanks
-Thanks
geposted Sun 21 Feb 16 @ 6:11 pm
The RX is not yet supported by VDJ.
See here http://www.virtualdj.com/forums/206198/Hardware_Technical_Support/Pioneer_DDJ-RX_Mapping__.html
geposted Sun 21 Feb 16 @ 6:23 pm
groovin is right.
you have to add the mapping first, then connect your controller
geposted Sun 21 Feb 16 @ 6:29 pm
Any idea when it will be ready to go? I need ASAP!
geposted Sun 21 Feb 16 @ 6:37 pm
Your answers are in the link provided above.
geposted Sun 21 Feb 16 @ 7:14 pm
ya
geposted Mon 02 Jul 18 @ 4:20 pm
