Scenario:
- VDJ ver 8.1.2844
- Default skin
- CrossFaderCurve=Full
- CrossFader=Disable
- CrossFaderCustom=
- CrossFaderHamster=no
- VideoCrossFaderLink=No
- VideoCrossFaderAuto=No
Action:
- Open VDJ
- Change option "VideoCrossFaderAuto"=Yes
- Close VDJ
- Re-Open VDJ, the option "VideoCrossFaderAuto" still "Yes " -> Ok, as expect
But:
- load a video track
- the option "VideoCrossFaderAuto" automatically switch to "No"
Why ?
- VDJ ver 8.1.2844
- Default skin
- CrossFaderCustom=
Action:
- Open VDJ
- Close VDJ
But:
Why ?
geposted Mon 22 Feb 16 @ 6:47 pm
Do you have the plugin "AutoVideoTransition" installed and enabled?
geposted Mon 22 Feb 16 @ 8:29 pm
Yes, it was installed, but I don't enable it.
Now I see it in AutoStart folder; I delete it and now VideoCrossFaderAuto always retain their setting.
Thank You for suggestion.
geposted Mon 22 Feb 16 @ 10:13 pm
AutoStart plugins don't need enabling, they enable automatically. The plugin itself has an enable parameter which is remembered across sessions.
When the plugin enable option is active, and video is active, it will automatically deactivate the auto video crossfader as this conflicts with the purpose of the plugin.
geposted Tue 23 Feb 16 @ 2:07 am
