In version 7, I was able to display a .jpg image on a deck just like a video. This gave me the ability to crossfade between images and video files. Is this possible in 8.1?
I already added (.jpg) to the codecs, and it displays the image in the "cover" area, but displays "ERROR" on the deck and does not output to video.
Thanks in advance!
Thanks in advance!
geposted Wed 24 Feb 16 @ 12:34 am
I don't think you can load a JPG file (drag it to a deck, it does not even display on the browser to be selected even in V7).
Did you just want to to display ONE image ? Where (second screen, or your screen) ?
If you have slideshow running and you playing video on the other deck, when you crossfade to the other side it will display the picture.
I guess I don't know what you are trying to do.
geposted Wed 24 Feb 16 @ 2:26 am
VirtualDJ 8 doesnt use external codecs and cannot load Image files to decks.
You can drop the image to a Sampler Slot and display/trigger it from the Sampler
geposted Wed 24 Feb 16 @ 2:34 am
Well shoot. I know this was possible in V7... I did it many times.
Here is the scenario...
I am running a "Night At The Races" fundraising event. The horses are all purchased and named prior to the event by attendees. I create a graphic of each race with the horse names and numbers. Then, after all bets are placed, I play the pre-recorded race video. Then, I display a graphic of the finishing order with horse names, race sponsors etc. It's a lot of crossfading between videos and graphics that was very easy in V7. I may have to reinstall 7 just for these events then?
geposted Wed 24 Feb 16 @ 4:20 pm
you better check out the LOTTERY plugin.
geposted Wed 24 Feb 16 @ 5:32 pm
ok, so a somewhat simple fix... I just rendered each JPEG image as a 1 second MPEG2 video file.
But, I would love to see this feature added to VDJ8. Would have saved me about an hour of work.
(Still love VDJ though)
geposted Fri 26 Feb 16 @ 12:48 am
It was a very convenient and fast function, on many occasions we do not have time to organize photos jpg with the sampler ...
I hope the Team increases the function
geposted Fri 26 Feb 16 @ 10:55 am
