Forum: VirtualDJ 8.1 Technical Support
Topic: Update box on start issue
Anyone having an issue when loading up VDJ - the update box asks if you want to use updated version, you select yes and the box doesn't disappear like before, stays there even though I have the latest download. If I select no then VDJ loads!
geposted Wed 24 Feb 16 @ 1:26 pm
geposted Thu 25 Feb 16 @ 1:57 am
RobRoyPRO InfinitySenior staffMember since 2012
deleting changelog.txt in VirtualDJ/ cache / does not solve ?
geposted Thu 25 Feb 16 @ 3:27 pm
@RobRoy:
No, this workaround does not solve this problem on Mac...
geposted Thu 25 Feb 16 @ 5:23 pm
Why is this not fixed yet?? Deleting the stuff from the cache folder does nothing.......
geposted Tue 01 Mar 16 @ 1:32 pm
We cant really reproduce it here and hard to fix of course, so please try the following... (some of them could be irrelevant, but u never know)..
- Check the Gatekeeper and see if it helps to turn it off.
- Check the Properties of the applications folder and the VirtualDJ folder (including the cache folder)
- Delete the .ready file from the cache folder.
- Restart your Mac (before trying out VDJ)
geposted Tue 01 Mar 16 @ 4:47 pm
MAC El Capitan Version 10.11.3, VDJ 8.1 build 2853.1116
checkUpdates: YES
EarlyAccessUpdates: YES
Tried this:
- set Gatekeeper off
- del the.ready file
- del changelog.txt
- restart
same result, sorry (Update-Box appears again and again)
If I close the window, VDJ start with the older version.
If I hit NO-Button, VDJ start with the older version.
If I hit YES-Button, the Box comes up again.
Hope these infos help to fix this problem....
geposted Wed 02 Mar 16 @ 6:55 am
deleting settings.xml along with the update.ready. and changelog.txt files, helps ?
you will probably have to re-enable the EarlyAccess setting though.
geposted Wed 02 Mar 16 @ 7:51 pm
No, deleted the files helps not. After a while the windows pop up and restarts the same procedure...
geposted Wed 02 Mar 16 @ 8:11 pm
geposted Wed 02 Mar 16 @ 8:15 pm
Did a clean install with build version 2857.1116 from my account.
VDJ starts and no windows pop up.
Settings:
  • checkUpdates YES
  • EarlyAccessUpdates YES
Wait for the next early update and hope it is fixed. Will give you a note anyway.Thanks for your support.
geposted Wed 02 Mar 16 @ 9:42 pm
dcomoPRO InfinityMember since 2012
I had seen this only once. The way that I had gotten around it was:
- Moved out my settings.xml file
- Deleted the VDJ App (Mac) and the VIrtualDJ folder from \Documents
- Re-installed with the latest release version and before opening, moved my settings.xml file back in
I then logged back in to create my license file, and then accepted the new 'Early Access' update, and life was back the normal.
geposted Thu 03 Mar 16 @ 4:45 am
