Mr DJ Mel wrote :
Yay!! Just seen that the latest build of VDJ now has support for the RX.
Will be trying this out the next few days to see how I get on.
How did you get on with this DJ Mel?
geposted Sun 30 Jul 17 @ 11:28 pm
hi folks,
updated VDJ and have tried this out on the RX but to be honest I'm not seeing any difference.
Is anyone experiencing the same thing as me?
what settings are you using on the RX?
cheers
Iain
cheers
Iain
geposted Mon 31 Jul 17 @ 3:11 pm
You need the latest *Early Access 3840. The current public doesnt include XDJ-RX support.
Manual : http://www.virtualdj.com/manuals/hardware/pioneer/xdjrx.html
*set the setting earlyAccessUpdates to Yes (from the Settings->OPTIONS tab of VirtualDJ
EDIT.
I see now that the XDJ-RX support was pushed in Public Build as well, but needs to silently download a file, so let the Public Build running for a while, and then re-open. You should get the functionality as per the manual
EDIT.
geposted Mon 31 Jul 17 @ 4:08 pm
need a mapper for pioneer xdj rx for windows 10
geposted Thu 10 Aug 17 @ 1:25 pm
