Hi guys, as the title says I've lost all my data. I havn't moved my database files or anything.
All tracks are showing up as "First time seen"
Is there any fix for this?
Thank you!
Thank you!
geposted Fri 26 Feb 16 @ 5:16 pm
just reboot vdj, I've had this happen before and I went mental, rebooting solved the problem, it might for you too.
geposted Fri 26 Feb 16 @ 6:24 pm
Thanks for the reply.
Yeah have tried 2 or 3 reboots with no luck!
geposted Fri 26 Feb 16 @ 7:00 pm
try rollback the database.xml?
geposted Fri 26 Feb 16 @ 7:33 pm
How do I do that?
And thanks again
And thanks again
geposted Fri 26 Feb 16 @ 7:38 pm
right click the database.xml you should see a Restore previous versions option.
geposted Fri 26 Feb 16 @ 8:06 pm
I'm running on a Mac, Don't think i have the option. Or are you doing this from within VDJ?
geposted Fri 26 Feb 16 @ 9:12 pm
i'm not a mac user. but this might be what you want.
http://osxdaily.com/2015/06/16/revert-to-prior-version-file-mac-os-x/
geposted Sat 27 Feb 16 @ 10:55 am
That's exactly what i was looking for thanks. Unfortunately there were no previous versions to choose from.
I really appreciate the help. Hopefully the VDJ support might have a solution for me.
geposted Sat 27 Feb 16 @ 1:31 pm
