i have an Asus with windows
virtual dj 8.1 full audio access
numark mixtrack 3
usb soundcard for headphones
I cant figure out why i can hear both tracks through my headphones when trying to cue, i have my audio set up....
speaker+headphones
no input
two souncards
-master = speaker output - internal soundcard - hd audio output #0 & #1
-headphones = 2-usb audio device - channel 1 and 2
also, why can i not adjust the bpm manually, the bpm analysis of the songs keeps messing up and i know the exact bpm but cant punch it in
numark mixtrack 3
speaker+headphones
no input
two souncards
geposted Fri 26 Feb 16 @ 7:11 pm
Check these for cue mix problem
For bpm
For bpm
geposted Fri 26 Feb 16 @ 7:57 pm
that was extremely helpful, i had the mix partially up and the problem is solved now, cant thank you enough
as for the bpm, right click does not work for some reason, its not that its a problem on my laptop, virtual dj just doest acknowledge i right clicked on the bpm, works on other parts of the system though
geposted Fri 26 Feb 16 @ 9:00 pm
I have had a problem with BPM in automix. Can not change the bad cues. Have to click on /2 or +2 in BPM Editor to fix the problem.
Sorry, but your issue, has nothing to do with this thread. Please do not hijack another persons thread, you may start your own, thank you AMAHM
geposted Sat 27 Feb 16 @ 1:26 am
user12334528 wrote :
t
which skin are you using/
geposted Sat 27 Feb 16 @ 2:53 am
