Hi,
Just installed the lastest VDJ upgrade and noticed that the software is now struggling to hold the beat in tracks with consistent BPM's, ie not variable.
I dont use beatlock, only sunc and then i manually adjust the jog weels as im an old skool dj at heart.
Since the latest upgrade im now finding tracks wont stay on sync but no idea what is causing it?
Using the Hercules 4mx with the latest drivers installed.
Thanks
Simon.
Thanks
Simon.
geposted Sun 28 Feb 16 @ 4:24 pm
....and if you revert to the previous version, the problem goes away?
geposted Sun 28 Feb 16 @ 4:50 pm
Tried this and it unfortunately didnt solve the issue. It started on Friday when i installed the update.
Ive tried two separate tracks but the beat match keeps drifting even though sync is enabled and there is an exact match.
Tried reinstalling VDJ 8 in its enirety and the 4mx drivers but still the same issue.
Could it be the controller is knackered?
I thought this was a software issue as the controller is for responding.
Anything else you can think off?
geposted Sun 28 Feb 16 @ 7:02 pm
Does it do it if the controller isn't connected?
geposted Sun 28 Feb 16 @ 9:22 pm
sbdj's is an important question, one more question, what build did you upgrade from [do you usually keep up to date with releases/]
geposted Mon 29 Feb 16 @ 12:49 am
Yes it does, however just got an update through and the issue seems to have resolved??
Most strange, but will revert when i test properly to see if there are still issues.
geposted Mon 29 Feb 16 @ 6:05 pm
