Forum: VirtualDJ 8.1 Technical Support
Topic: COMMANDS PIONEER FAIL[?]
hi guys, i have a problem w my controller pioneer sr
none command in left side it works right.
i press FX and the slip/deck2 turns on
i press HOTCUE and video/screen resolution turns on
i press KEY and padplus/auto-loop turns on
i press SYNC and cue/deck3 turns on
[all just in left side] I already checked all configs and custom maps, i reinstalled virtual dj and drivers, firmware last version.
someone can help me please? ps: srry for my english
geposted Mon 29 Feb 16 @ 9:45 am
What is the exact version of VDJ you are using?
geposted Mon 29 Feb 16 @ 10:20 am
version 8.0.
geposted Mon 29 Feb 16 @ 12:21 pm
Its a common hardware fault on the DDJ-SR (seen it lots of times - including my end). You need to contact with Pioneer and/or visit a Service Point. Most likely the main-board of the unit needs to be replaced.
geposted Mon 29 Feb 16 @ 1:21 pm
oh, i really did not expect for this..
I will have to stop the controller for a while due to the high cost of maintenance in brasil.
but really thanks to attention. =)
geposted Tue 01 Mar 16 @ 3:10 am
