I am having a problem with the pitch button variation on VDJ8. I am bent on using the Mix Lab skin, having used it for years with VDJ7.
In VDJ7 with Mix Lab 3.1, when I pressed the pitch buttons above or below the pitch reset beside the slider, it behaved reasonably by adjusting the digital readout +/- 0.1.
In VDJ8 with Mix Lab, when I press the same button, it now behaves entirely differently, adjusting the value +/- 1.25%. I need to be able to match to the tenth like I used to when mixing manually. I can't figure out how to get it to behave like it used to. Is there a way? Please say there is.
(I have adjusted the mapper. The label reads properly but the undesired effect still results.)
geposted Fri 04 Mar 16 @ 7:53 am
