Hi guys, just installed VDJ8 and I'm having trouble getting the videos to play smoothly.
My system is Windows 10 / i7-6500u / 16GB ram / 1TB hard drive
The video max memory has been set to 4000MB.
Not sure why this is happening, I didn't buy an expensive ass computer so I could have shit not work, but I'll see what advice you guys can give me.
Thanks!
Thanks!
geposted Fri 04 Mar 16 @ 11:26 pm
Also, it does not seem to be allowing me to load videos on the same deck as an audio track, which is weird, because I know I've done that when I've tried out VDJ in the past.
geposted Fri 04 Mar 16 @ 11:28 pm
geposted Sat 05 Mar 16 @ 2:59 am
Ok, so I think I've found the source of the issue. The buffering/lagging always happens on the beat to the audio. VDJ is trying to restart the video loop every x number of bars based on the audio and it is causing it to freeze up when it goes to restart. Is there a way to disable this tempo sync auto restart thing?
geposted Sat 05 Mar 16 @ 5:00 am
So you are having the problem only with edits where you linked a video track to an audio track?
geposted Sat 05 Mar 16 @ 7:39 am
Yes, I think so? I'm not totally familiar with the interface yet, but I think that might be it.
geposted Sun 06 Mar 16 @ 3:12 am
