Which do I keep?
![](/image/3090/182534/Screen Shot 2016-03-06 at 15.55.19.png)
geposted Sun 06 Mar 16 @ 3:57 pm
For VDJ 8, none of them.
For VDJ 6 and 7 the "VirtualDJ Database v6.xml".
If you wonder, the V8 database is called "database.xml".
You should find it in the "VirtualDJ" folder that folder should be in the same folder as the above database files.
geposted Mon 07 Mar 16 @ 9:59 am
