Hi!
Now my question is in a right place.
I have question. I have also a picture. Virtual DJ 8 shows that Mixtrack Pro 3 is connected (lights are on but buttons dont work in Audio section). In controller section I cant see my controller, only a strange symbol (in picture). I have Mac.
Can someone tell whats the problem?
geposted Sun 06 Mar 16 @ 7:33 pm
Is the /Documents/VirtualDJ/Devices folder empty ?
Can you post a screenshot of the Midi Studio ? (Applications-->Utilities->audio Midi Setup .. then from the Top menu choose.. Window->show Midi Studio)
Did you try a different USB port/USB cable ?
geposted Mon 07 Mar 16 @ 1:32 pm
Hi!
Yes, the folder is empty. Also I tryed different USB ports but with the same cable. But I havent changed the cable and I think thats not the issue because same cable is workgin with Mixtrack Pro II.
Here gomes the screen picture.
Thank you!
Thank you!
geposted Mon 07 Mar 16 @ 3:51 pm
Hi again!
Thank you for the comment because of that I now found whats wrong and everything is workin now! :)
MIDI setup was wrong :)
Thanks for your help ;)
geposted Mon 07 Mar 16 @ 3:54 pm
