Forum: VirtualDJ 8.1 Technical Support
Topic: Automatic pad layout
Hi im using a behringer cmd lc1 to trigger hot cues and a cmd dc1 to trigger samples. The only problem is when i use them together the automatic pad layout is 32 pads for the lc1. When i use just the dc1 i get 16 pads. The lc1 seems to override the dc1 even though its not used for samples. How can i stop the lc1 from doing this?
geposted Thu 10 Mar 16 @ 9:15 pm
Both controllers have Sampler Matrix internally defined and by default VirtualDJ will automatically select to use the largest Sampler matrix.
Currently there is no easy way to change that.
You could of course choose some specific Layout instead of the automatic (from the Sampler Options), but not sure if that will fit to the Controller's Pads layout.
geposted Fri 11 Mar 16 @ 12:01 am
