Hey Guys ,
I have contacted VDJ support but i was suggested to do a chat session for this problem, Chat is always unavailable . I am in Canada so maybe there is a time difference .
Anyways, My problem is that i am using DDj Sx and VDJ8 controller licence.Every time i shut down VDJ it erases all the bpms stored during that session.
I was go told to go on the link below and follow the steps and i did it but i still have the same issue.
http://www.virtualdj.com/wiki/VirtualDJ%20Folder%20Permissions.html
Can someone help ?
Can someone help ?
geposted Sat 19 Mar 16 @ 1:38 pm
have you check to see if readOnly in options is switched to off
it's in the browser section and advanced settings may need to be ticked to see it.
geposted Sat 19 Mar 16 @ 1:41 pm
is this the same problem as here described?
http://www.virtualdj.com/forums/206034/VirtualDJ_8_1_Technical_Support/MP3_tagging_issues.html
geposted Sun 20 Mar 16 @ 2:39 pm
I've just switched from the PC version of VDJ8 on a boot camped Mac to the Mac version last week and found this readOnly setting default to YES. Switched to NO and everything is OK now.
Seems odd to have it default to YES.
geposted Sun 20 Mar 16 @ 2:59 pm
The default is definitely NO.
geposted Sun 20 Mar 16 @ 3:22 pm
