Hi! I got question ! If i pay one time 99 dollars for Pioneer ddj sb2 controller to unlock it on vdj 8.1 , is it just one time payment ? then i can use it all time when i want ! not to pay per month regulary it ?? thanks! and can i record mixes too then ?
geposted Sun 20 Mar 16 @ 3:39 pm
Yes, you only pay once - but the license is only for private home use.
Also, if you buy another controller in the future, you will need to buy a license again.
Only the Pro Infinity license or monthly subscription license allow professional use and work with any controller
geposted Sun 20 Mar 16 @ 3:45 pm
Thank You - That i wanted to know !!! thanks!
geposted Sun 20 Mar 16 @ 4:02 pm
I pay for the Infinity Monthly! Renews Every 40 Days, if you have made payment that is, try it for a month, then if you can afford to buy the Software Out Right, Infinity Unlimited witch allows you to put it on 2 Machines, I.e Laptop, Desktop Pc, Mac etc..
If your Just using it for bedroom DJ'ing and not making a living from Gigs, probably the home version is best for you..
geposted Sun 20 Mar 16 @ 7:00 pm
I used the software only on home, I can get it on pay ment
geposted Sun 10 Dec 17 @ 6:21 am
Virtual Dj is changing My mind About SERATO...
geposted Mon 09 Apr 18 @ 2:14 pm
