The Master Effect doesn't save its setting,it goes back one of the deck effect settings after restarting VDj-8/open . Any help.
geposted Tue 22 Mar 16 @ 11:32 pm
Same case if an Effect is selected on both decks.
The ini file only stores one Parameter value (not per Deck), so probably you have the same Effect selected in a FX Slot on Deck Left/right instead of just the Master.
geposted Wed 23 Mar 16 @ 1:06 am
Ok so you saying no individual perimeter on the same effect diffident slots .
geposted Wed 23 Mar 16 @ 4:36 pm
You can have different values (e.g. 50% on deck 1 and 0% on deck 2 while playing/using the Effect) but only one value will be saved across sessions.
geposted Wed 23 Mar 16 @ 5:29 pm
