Forum: Old versions
Topic: MCX8000 support - Page: 4
To everybody that worked hard on making this mapper:
Thank you, and congratulations for the fantastic job. I am impressed how well the controller is behaving with VDJ 8.2, the Sampler Pads, changing colors, the Sampler Inpendent volume control, everything!
The only thing I could find that needs some tweaking is the Audio FX buttons, the 3 buttons should be used for 3 different efx, now they all do the same thing. Other than that, it's perfect!!
geposted Sat 25 Jun 16 @ 4:02 am
SHIFT+TAP button should change the Single FX mode to Multi FX mode, so that you have 2 FX slots instead of 1.
geposted Sat 25 Jun 16 @ 12:38 pm
Hey guys, thank you so much for the mapping. Absolutely incredible!!! Compliments for such a nice work. Nearly time to kick Serato into the trashcan. Can't await the screens working. But anyway, I have a question are you guys working on such a nice thing like pitch n time?
This would just be great to have the full, 100% functionality of the controller...apart from the slip-mode.
Thanks for your answer.
geposted Sun 26 Jun 16 @ 10:58 pm
geposted Mon 27 Jun 16 @ 10:08 am
Wooohah, emberassing for me!
Exactly what I mean!!!
Thanks alot! And sorry for my blindness :-)
geposted Mon 27 Jun 16 @ 2:50 pm
geposted Wed 29 Jun 16 @ 6:11 pm
dcomoPRO InfinityMember since 2012
No expensive plugins needed here... You have a license, you get really cool stuff for no additional cost!
geposted Thu 30 Jun 16 @ 5:26 pm
hello
can someone send me the mapping file fot the mcx8000.
best regards
geposted Sun 10 Jul 16 @ 3:15 pm
geposted Sun 10 Jul 16 @ 5:40 pm
Hello, ( i´m from german)
i have a problem with the gain, when the track start the gain automaticly goes in the middle, but this is
to much and the red led (clipping) goes on. What can I do, that the gain is allready escat on the same point?
Thanks for help!!!
best Regards
DJ Bernd
geposted Fri 22 Jul 16 @ 5:14 am
Change "zeroDb" setting to a lower value. -3db is a good value, but you can try the rest settings as well.
geposted Tue 26 Jul 16 @ 5:04 pm
user11841777 wrote :
... the red led (clipping) goes on.
If you refer to the LED named as LIMITER at the top of the VirtualDJ skin, then yes, lowering the zeroDB setting is a good choice.
But if you refer to the top red LED of the VU meters on the MCX8000, then this doesnt indicate clipping (Limiter engagement ) read here http://www.virtualdj.com/forums/200863/General_Discussion/Adjusting_the_Level_of_Auto-gain_to_avoid_the_Limiter_from_kicking_in__please_help____.html?page=2 my post and see pics.
geposted Tue 26 Jul 16 @ 6:25 pm
who or where is the mapper for the mcx 8000. I cannot seem to find it. sorry if this has been posted or not
geposted Fri 08 Jun 18 @ 7:03 pm
it is built in to VDJ 8 nothing to find
geposted Fri 08 Jun 18 @ 7:09 pm
how do I get it to work properly with the mcx 8000. still having sound issues with the sound dropping out
geposted Fri 08 Jun 18 @ 7:12 pm
That's an issue with the Denon Asio drivers. Increase the latency in the Denon control panel assuming you are Windows and have installed the Denon drivers.
geposted Fri 08 Jun 18 @ 7:39 pm
thanks increased it but still have the audio dropping out and freezing up
geposted Fri 08 Jun 18 @ 9:02 pm
Optimise your computer. Check for DPC latency spikes.
geposted Fri 08 Jun 18 @ 9:03 pm
my email is djgeppy@gmail.com
can someone email the mapper please.
thanks in advance
geposted Fri 08 Jun 18 @ 9:05 pm
There is no mapper.
geposted Fri 08 Jun 18 @ 9:24 pm
99%
