For reasons too lengthy to describe ....
Is there a way to assign (embed) ONE stock image to be used as the "Cover Art" for all tracks you have?
The Track editor lets me pick an image from the Covers directory, but won't let me pick the image AND ASSIGN IT to ALL tracks (even though it will for some).
Further, I can't tell in the .xml file how it knows where/what image is actually embedded. I can tell, however, that it is an "embed" situation because not all pics actually being stored and used in VDJ are actually in the Covers directory.
Any clues on this would be appreciated..... thanks.
geposted Thu 31 Mar 16 @ 8:18 pm
re curse all folders, select all tracks then open tag editor, click on cover art square then simply drag whatever image you like from your computer drag into the image square and then press ok, that will give every song the same image
geposted Thu 31 Mar 16 @ 9:21 pm
Sweet. Thanks!
geposted Fri 01 Apr 16 @ 12:01 am
