Since build 2857, VDj can no longer close. I take the task manager to close.
geposted Fri 01 Apr 16 @ 9:03 pm
you probably have ShopDemoMode set to YES.
when you have VDJ closed, edit your XML file and search for DEMO
<shopDemoMode>no</shopDemoMode>
it should be like that.
geposted Sat 02 Apr 16 @ 2:57 am
In the settings, shop demo mode is "no". This is the copy from the settings.xml : <shopDemoMode>no</shopDemoMode>
geposted Sat 02 Apr 16 @ 11:31 pm
try re-naming your XML file (just for backup) and try it. Then you can put it back.
That's all I got.
That's all I got.
geposted Sun 03 Apr 16 @ 4:19 am
I've tried. Still the same.
geposted Sun 03 Apr 16 @ 6:39 pm
Sometimes it's happened to me too, but in rare case: I don't know the combination of action that cause it.
geposted Mon 04 Apr 16 @ 8:59 am
Hi Baustell,
I can reproduce that, using FRUiT's skin if I lock the window I can't close the program.
So maybe you have your window locked in some way
Hope that helps
ray
Hope that helps
ray
geposted Mon 04 Apr 16 @ 10:15 am
@ raypitman: Sorry doesn't work. My skin is re-condensed. I've tried some other skin locked and unlocked. Still the same problem.
geposted Mon 04 Apr 16 @ 5:43 pm
do a fresh rein install, save your xml files
geposted Mon 04 Apr 16 @ 7:06 pm
i wonder if this has anything to do with exclusive audio access
2 days ago, I've made an re install. Can I go back to an earlier Build.
exclusiveAudioAccess is "no".
geposted Mon 04 Apr 16 @ 9:15 pm
What sound interface do you use ?
Anything from M-Audio ?
geposted Mon 04 Apr 16 @ 10:10 pm
The soundcard from Denon MC 6000. Nothing from M-Audio.
geposted Tue 05 Apr 16 @ 3:40 pm
See in Audio Midi Setup (in Utilities) if the MC6000 is selected as default sound card for OS. If so, set your computer's built-in sound card as default and test again
I also wonder if there is something wrong with database, so remove (backup) the database.xml from /virtualDJ folder and see if this helps.
Last but not least, check the Permissions of the /VirtualDJ folder
geposted Tue 05 Apr 16 @ 8:51 pm
