Hello Fellow DJs,
I'm new to VDJ, but am totally impressed with v8.
I have a NI S2MK2 and an F1 connected. I have a couple of issues...so far.
But my main 2 issues is the following :
1) On the F1, the 4th volume slider doesn't work. I was decent at mapping the midi in Traktor Pro but can't seem to get this working on the F1.
2) On the S2, I only get the slot 1 FX to work, and that effect is routed to both the wet/dry and #1 knobs.
This is how it came default.
Any help is appreciated.
Thank you
Thank you
geposted Sat 02 Apr 16 @ 3:28 pm
1) Have you changed the action of the fader or using the default one ?
By default, the 4th fader is mapped to control the Volume of the 4th Sampler Group. It wont do anything of course if the Bank only has 3 Groups (like the Instruments bank)
2) As far as i can see from the default mapping, the WET/DRY FX knob is assigned to select the Effect , not to control any parameter.
The S2MKII offers 2 Effect modes (Single and Multi). Read further details in the manual http://www.virtualdj.com/documents/Native%20Instruments%20Traktor%20Kontrol%20S2%20MK2%20VirtualDJ%208%20Operation%20Guide.pdf
geposted Mon 04 Apr 16 @ 12:36 am
Thanks DJ Dad. I'll check it.
geposted Tue 05 Apr 16 @ 3:13 am
DJ Dad,
YOur suggestion did help. Thanks
geposted Tue 05 Apr 16 @ 4:51 pm
