Forum: VirtualDJ 8.1 Technical Support
Topic: NI S2MK2 Midi Mapping
Hi,
Does any one use and/or have midi mapping chart for the S2 MK2. Trying to get the FX knobs and buttons mapped. Everything else seems well mapped
geposted Tue 05 Apr 16 @ 3:15 am
I did find the VDJ manual for the S2 midi overview. I tried the "Hold Shift" on deck 1 and pressed the FX1 Wet/dry button they function as desired. FX1, 2 and 3 button turn fx on & off and knobs work. But when I try on FX2 all knobs same fx.
Any help would be great.
geposted Tue 05 Apr 16 @ 4:02 am
You need to repeat the same procedure on FX2 side as well
Hold down SHIFT on right side and press FX2 Wet/Dry button.
Now FX2 section should also switch to "MultiFX" mode.
If you always want your unit to start on "MultiFX" mode then add the following code at the start of the <ONINIT/> element of your mapper:
set '$fx1multi' & set '$fx2multi' & (original contents go here)
geposted Tue 05 Apr 16 @ 10:09 am
Thanks Phnatom. I took the code you gave and did work for the most part. Only thing all FX2 knobs control FX2 knob 1 rotary. Knob 2 & 3 dont work.
geposted Tue 05 Apr 16 @ 1:00 pm
With this command on the ONINIT element
set '$fx1multi' & set '$fx2multi' & set '$fx1' 1 & set '$fx2' 2
everything works fine here.
Mind you that you must select effects on the slots 2, 3 &4 on each deck, and that the selected effects must have a slider element
So, press SHIFT+ ON buttons at least once on each side of your controller to select an effect for each slot.
You can also expand the EFFECT section on the default skin to see the selected effects and select others from there, but it only shows slots 1,2&3. Not 4.
geposted Tue 05 Apr 16 @ 1:18 pm
Thanks Phantom,
That did help and the paste of the code as well.
geposted Tue 05 Apr 16 @ 4:52 pm
Phantom,
That dod work well. Only thingis that the knobs on FX2 only control the 3rd FX level.
I've tried to adjust code, but no luck for me.
Any ideas would be helpful.
Thanks
geposted Tue 05 Apr 16 @ 9:14 pm
deldelon wrote :
Thanks Phantom,
Phantom,
Thanks
