Topic: Using effects and music stops.
apexdjsPRO InfinityMember since 2009
Anyone know why when I try to use sound effects on my laptop the music will just stop. For example: I hit the brake effect and the song will instantly stop.
geposted Mon 11 Apr 16 @ 5:22 am
That's normal for the brake effect.
It simulates the brake (Start/stop) of vinyl.
Change the fx-parameter and you'll see.
geposted Mon 11 Apr 16 @ 5:44 am
If this is the effect you are talking about, I am laughing very hard. Think about it, you know that's funny. However, if other effects are making the player or software stop, that is an issue.
geposted Mon 11 Apr 16 @ 7:57 pm
Thanks. The parameter settings where off. Never even dawned on me to check. Works great now.
geposted Tue 12 Apr 16 @ 3:44 am
Agree with you. This is something for the best of.
Anyway, sometimes anyone of us can't see the wood for the trees ;o)
geposted Tue 12 Apr 16 @ 8:32 am
can i use video transitions of virtual dj 8 in virtual dj 7
geposted Tue 12 Apr 16 @ 11:23 am
No.
geposted Tue 12 Apr 16 @ 11:25 am
labbedjPRO InfinityMember since 2013
I really like the brake effect but it should have more parameters and specially a release at normal speed option not a slow-to normal. Maybe if this not possible a slip option to continue playing. ( like the one on rekordbox)
If someone know a VST or options to a better brake please tell us here. thanks
geposted Tue 28 Mar 17 @ 12:52 am
There is a slip-break effect in the downloads:
http://www.virtualdj.com/plugins/index.html?category=effects&search=slipbrake
geposted Tue 28 Mar 17 @ 5:42 am
Hello I just bought a DDJ-SX2 I am looking for a way when I press the button PLAY/PAUSE, virtualdj stops the music using a brake... Can anyone help?
Thanks
geposted Sat 01 Jul 17 @ 5:11 am
in options
rampStopTime = 0 ?
geposted Sat 01 Jul 17 @ 6:09 am
He wants play/pause to be play/brake.
I think it would be possible with a little VDJScript. One of our forum script gurus will help.
geposted Sat 01 Jul 17 @ 6:52 am
rampStartTime / rampStopTime
do this, no need for scripting.
geposted Sat 01 Jul 17 @ 7:25 am
Here is a video showing a few ways to do this:
geposted Sat 01 Jul 17 @ 11:20 am
