I've been playing with the POI editor to see if I can use it to automate "tails-out" looping.
I take a track, assign a cue-point (like 4); then edit the POI to say...
Cue 4 / "Action" / Under Macro "Loop 16"
In ALL instances, the loop will engage. The problem is that in most cases (but not all) it only loops once, then proceeds with the rest of the track. I need it to always repeat the loop until I'm done with the track.
Is this a bug, or am I doing it wrong?
Thanks.
Thanks.
geposted Fri 15 Apr 16 @ 5:09 pm
Any chance between Cue 4 and the next 16 beats there is another Cue that has the same action and cancels the loop ?
Do you have Loop Back mode enabled ?
Can you spot the track inside your database.xml file and port its info here ?
geposted Fri 15 Apr 16 @ 6:41 pm
1. No other Cue Points (or song end) in the way.
2. LoopBack No.
3. Text in database follows:
2. LoopBack No.
geposted Fri 15 Apr 16 @ 6:54 pm
Looks like it is the same issue like here:
http://www.virtualdj.com/forums/208945/General_Discussion/Action_Loop_Length_.html
loop ? nothing : loop 16
Might do it.
Might do it.
geposted Fri 15 Apr 16 @ 7:21 pm
Would you believe? That works! Didn't think (that) that would require xml lingo.
Thanks!
Thanks!
geposted Fri 15 Apr 16 @ 7:39 pm
