Forum: VirtualDJ 8.1 Technical Support
Topic: Can't sign onto Sever
Hello My name Franki I'm having problem logging into Virual DJ.
Keep saying that system unstable because of crack installed however there is no crack install on my laptop
because i bought my self Virual Dj pro Subscription but i can't seem to log into the sever
please help me im very pissed!!!
geposted Sat 16 Apr 16 @ 4:33 am
Maybe not now - but has there ever been one installed, in the past?
You should try cleaning your hosts file. There's a utility available here
geposted Sat 16 Apr 16 @ 8:31 am
thanks and yes before but I want to become real member so bought it
geposted Sat 16 Apr 16 @ 12:23 pm
The crack modifies the hosts file, so even when you've uninstalled the dodgy software, the symptoms remain.
Did you run the cleaner and fix the problem?
geposted Sat 16 Apr 16 @ 12:25 pm
Hay guys I had the same problem now it fix go to system32\drivers\etc\hosts file and open it with notepad and see if u find any thing like this '127.0.0.1 live.virtualdj.com if so just delete it out and save the file with notepad as a pad file and take out the extension code now re install and try login
You are back in business guyss
geposted Mon 15 Aug 16 @ 6:17 pm
