Hercules dj console rex does not respond on virtual dj 7. I bought it with virtual dj 5.
the skin is also not the one corresponding to the hardware.
What can I do?
Julian
What can I do?
Julian
geposted Sun 17 Apr 16 @ 10:50 am
This is all on the same computer or did you change since buying the Rmx ?
Is the Rmx correctly enumerated and installed on your computer ?
http://ts.hercules.com/faqs/eng/her_eng_00351.pdf
If this seems to be the case, can it be used as a MIDI controller outside of VDJ ?
http://ts.hercules.com/faqs/eng/her_eng_00352.pdf
geposted Mon 25 Apr 16 @ 12:12 pm
is that the LE or pro ? also ( VDj-5.2)
geposted Wed 27 Apr 16 @ 1:24 am
