Forum: VirtualDJ 8.1 Technical Support
Topic: analogue mixer licence required
just recently ive had a message coming up after 10 mins stating 'analogue mixer licence required'.
Ive got the correct controller licence and had no issues for past year or so, any ideas as to why this is coming up all of a sudden?
cheers
geposted Mon 18 Apr 16 @ 5:20 pm
What controller are you using?
Are you using it with the correct settings, or have you added something (another input or output)?
geposted Mon 18 Apr 16 @ 5:59 pm
Assuming that you are using the Hercules DJ Instict (as seen in your Account User details), you will need to keep the Audio Setup as Master & Headphones (no Deck 1, Deck 2, LineIns, Timecodes etc - those will require Plus or Pro Infinity license)
geposted Mon 18 Apr 16 @ 6:23 pm
thanks for getting back. yep i had the wrong settings. cheers
geposted Tue 19 Apr 16 @ 6:21 pm
