Hi guys, actually i change to version 8.1, and now i got a video problem. when i put a video on deck A. all work fine. but. when i put anoher video on deck B or the same video.. and i play it. the video on the deck A start a flashing.. a little. like a white flash effect. and the same on invert way. any ideas?
My PC Windows 10
Intel I7
16GB RAM
GTX 650 2GB VRAM
Thanks!
My PC Windows 10
Intel I7
16GB RAM
GTX 650 2GB VRAM
Thanks!
geposted Wed 20 Apr 16 @ 10:52 pm
try changing videousedxva setting.
geposted Thu 21 Apr 16 @ 2:48 am
Hi! thanks for answer. i already tried.. enable, disable.. same result.
geposted Thu 21 Apr 16 @ 2:54 pm
Perhaps check the transition selected or any video effects active
geposted Thu 21 Apr 16 @ 3:37 pm
no effects active, in fact, if i put one video, and add some loop video in alpha from video loops, the same flash appears on video.
Thanks for reply !
Thanks for reply !
geposted Fri 22 Apr 16 @ 7:43 pm
See if this happens with another Video Transition
geposted Fri 22 Apr 16 @ 11:26 pm
Is video transition set to auto?
geposted Sat 23 Apr 16 @ 7:58 am
set auto.. or not, i already tryed all. i will try changing the video card, to a gtx970. 4gb VRAM. i hope with that all go fine. thanks all for the answers!
geposted Thu 05 May 16 @ 2:41 pm
