It's been discussed here before, however still got the problem.. Neither hot cue points nor normal cue points are being saved after I exit out of VDJ.
They stay if I unload the track and load again within the same session.
Windows 10. What can I do about this ? Asap. Thanks!
geposted Wed 27 Apr 16 @ 12:11 am
getCuesFromTags setting (Advanced settings) is set to always maybe ?
geposted Wed 27 Apr 16 @ 2:04 am
it was for new files only.
Just to make sure I do everything correctly..
1. open VDJ
2. load a song
3. set couple of hot cue points
4. close VDJ
5. open VDJ
6. load the same song again
7. all cue points lost
Tried re-installing (to a default location on C:\). Nothing helps.
1. open VDJ
2. load a song
4. close VDJ
5. open VDJ
geposted Wed 27 Apr 16 @ 9:07 am
