Hi all
this is my first post on here so forgive me if its not right.
i am trying to install a denon mc6000 midi map,i download it from the download section and installed it, looked in the mappers folder within VDJ and sure enough its there but when i start up VDJ and go in to setup / controller and use the drop down menu its nit there.
can anyone help please, im sure its something silly im missing here.
geposted Fri 29 Apr 16 @ 7:07 am
You don't need an external mapper for the MC6000, it's built in to the software.
geposted Fri 29 Apr 16 @ 8:20 am
Yeah I know but it does not work as I want it to so I'm wanted to try a few others
geposted Fri 29 Apr 16 @ 10:24 am
For the mapping to show up you need to have the controller connected.
geposted Fri 29 Apr 16 @ 11:55 am
yeah i done all that i even reinstalled vdj and still no joy
geposted Fri 29 Apr 16 @ 12:06 pm
Try renaming the XML file to "forceNewMC6000" and see if it shows up.
I to have had problems with mappers not showing up, not sure why it happens but it does happen from time to time.
When it does happen I just trash it.....
geposted Fri 29 Apr 16 @ 4:13 pm
which mapper ? link ?
geposted Fri 29 Apr 16 @ 6:44 pm
