I am having a problem in Virtual Dj. I have two CDJ-900 running through a mixer. In virtual dj preferences I can only select one CDJ for the soundcard. This means that If I am playing from either Turntable 1 or turntable 2 it will only play if the fader is completely to one side. I am trying to get it so I can get audio from another decks through the mixer so each channel on the mixer is set up to the turntable. I am CDJ Aggregator so the turntables are set up fine. To be clear I can set up both turntables for the soundcard. But can only slects one at a time Please help.
geposted Fri 29 Apr 16 @ 10:12 pm
Try disable the crosfader. In audio config section select EXTERNAL MIXER.
geposted Mon 02 May 16 @ 1:33 am
