When I backspin on it affects my master output as if skipping foward on the existing deck during the backspin and the other deck that is playing. This also occurs when I use the Strip Search or skip mode while another deck is playing. I am using V8.1 PC build 2857.1116 with a pro-infinity license on a Windows 10 OS. The controllers I am using are an Numark NS6 and a Launch Pad. My controller options are backspin yes, touch wheel spin threshold 1.000.
geposted Sun 01 May 16 @ 1:41 pm
My wheel spin threshold set to default 0.80000 with a different controller. Try it.
geposted Mon 02 May 16 @ 2:02 am
Thanks I'll give that a try.
geposted Tue 03 May 16 @ 5:19 pm
