Since a version or so ago video transitions with Automix have gone bad.
They now mix in the following song into the transition effect. So the screen shows song C while fading between A and C.
I have just noticed that it doesn't do with when running alone -no external video or turntable.
MacOS
MacOS
geposted Tue 03 May 16 @ 9:39 am
I see now that it doesn't do it when "Link" is on. But still shouldn't be showing song C anyway.
geposted Tue 03 May 16 @ 9:41 am
The problem was caused by the third-party plug-in AutoVideoTransition.
Removing it fixes for everything except with the third-party transition "Mask". -that works fine except in Automix.
geposted Fri 06 May 16 @ 11:17 am
