Forum: VirtualDJ 8.1 Technical Support
Topic: Virtual DJ and Loop Roll
Good Evening Sirs! Could you help me please ? Just trying to map a button on my lpd 8.
Want to do this:
Button 1 - deck 1 effect_active Loop Roll while_pressed (what should i add to do make this button work only with 1/4 beat loop roll ?)
Button 2 - deck 1 effect_active Loop Roll while_pressed (what should i add to do make this button work only with 2/4 beat loop roll ?)
and so on.
Thanks a lot!
geposted Tue 03 May 16 @ 5:21 pm
You can literally just use:
deck 1 loop_roll 0.25
geposted Tue 03 May 16 @ 6:35 pm
Thank you so much!
geposted Wed 04 May 16 @ 3:09 am
