Forum: VirtualDJ 8.1 Technical Support
Topic: Karaoke Zip
pipmilPRO InfinityMember since 2010
Hi, on zipped karaoke files they don`t show up as full title e.g. SF001-01 - Paula Abdul - Straight Up (UNZIPPED) and Paula Abdul - Straight Up (ZIPPED) this makes it longer to find the right song version ? on Vj7 this was not a problem??? is there a way to show full title on zipped files. The search on Vj8 is not as good as Vj7 ??? Thanks Phil
geposted Tue 10 May 16 @ 9:27 am
Try these options:
geposted Tue 10 May 16 @ 9:35 am
The catalog id is stored in the comment field, so just show the comment field in the browser and activate the comment field in the search options if you need it.
geposted Tue 10 May 16 @ 11:09 am
