Forum: VirtualDJ 8.1 Technical Support
Topic: Application crash
I am using 2 CDJ 700s and when I connect the second unit as MIDI the VDJ app crashes. Using Gemini ASio and have tried changing the buffer, the Ticket support is unable and unwilling to help. Can anyone suggest a fix
geposted Tue 10 May 16 @ 2:59 pm
Are you connected to the internet at the time of your crash?
When you say crash, can you describe exactly what happens?
geposted Tue 10 May 16 @ 7:31 pm
Yes I am connected to the Internet , The VDJ application does not respond and I get the message the app has stopped working, and it closes and I have manually open the VDJ app again
geposted Tue 10 May 16 @ 10:18 pm
This occurs as soon as you connect the second unit? Are you doing this before the application starts or after? If before, I assume it crashes immediately?
geposted Wed 11 May 16 @ 2:13 pm
Correct , Sorry didn't get the second part of your question
geposted Thu 12 May 16 @ 11:47 am
