I have the virtual dj 8.1 for DDJ SB.
When I open the program, the deck A starts playing fine but after several musics it simply stops.
I can only get it to play again if I restart the program.
What should I do?
I can't stop the music and restart the program everytime it happens.
Does anyone know how can I fix it?
What should I do?
geposted Fri 13 May 16 @ 5:18 pm
What build of VDJ 8 are you using? Has the problem just started, or has it always happened?
Did you try using another skin?
Does this only happen when the SB is connected (does it work OK without the SB)?
The music you're playing - where does it come from? Is it music you own, from your hard drive, or are you streaming it from Content Unlimited / Netsearch etc?
geposted Fri 13 May 16 @ 5:33 pm
What OS (win/mac/version)?
geposted Fri 13 May 16 @ 5:47 pm
What you mean by "what build of VDJ8"?
The problem started today, but I starded using the VDJ yesterday. I bought yesterday the license.
No, I didn't try any other skin, you think it may help?
I also didn't try to use it without the SB, I want to use with the contoller.
The music I'm playing is mine not stream. And when it stops, it's only deck A, and i cannot play any other music, I am able to change musics but when I press play it doesn't start.
I'm using OS X El Capitan 10.11.4
geposted Fri 13 May 16 @ 9:12 pm
