geposted Mon 16 May 16 @ 1:42 am
"default", "sidelist" and "karaoke" are three playlists that are created automatically when you shut down VirtualDj and they keep the contents of "Playlist", "Sidelist" and "Karaoke" views respectively.
Their contents change each time you shut down VirtualDj based on the contents of those 3 windows.
You can change that behavior by changing the "savePlaylist" option.
geposted Mon 16 May 16 @ 3:37 pm
Thanks Phantom, wondered what was going on, fixed it.
geposted Tue 17 May 16 @ 3:41 am
