Hello Folks.
I Tunes does not appear on VDJ 8 when I add it to my root elements I am running itunes 12. Does anyone have a solution.
geposted Mon 16 May 16 @ 9:15 am
Make sure the setting for "iTunesDatabaseFile" is pointing to the correct location on your computer
geposted Mon 16 May 16 @ 9:29 am
Make sure you share your ITunes library with other applications.
More infos about that you can find here:
http://www.virtualdj.com/forums/203184/General_Discussion/iTunes_12_Compatibility_.html?search=itunes%20share%20xml&page=1.3
geposted Mon 16 May 16 @ 10:04 am
