Forum: VirtualDJ 8.1 Technical Support
Topic: xdj-rx
Hello, I report the following,
1 crosfader moves, but not mix the decks, in the master output, the probe mixture with USB flash drive and it works ...
2 pres doghouse on cue, single speak not work ...
3 the filter does not work, and buttons to activate either ...
4 The active effects bbuttons effect, not the first asigned...
geposted Mon 16 May 16 @ 3:01 pm
